Royal Star
maniek1z
  • 3 tygodnie później...
The drive package on the Royal Star includes a liquid cooled 1298cc (referred to as 1300cc) V-4 engine. It has four valves per cylinder, overhead camshafts, and shim over bucket valves. The five speed overdrive transmission is part of the engine case and both the engine and transmission share oil. The drive accuplacer exam shaft and final drive assembly are built into the left side of the double sided swing arm. Swing arm motion is damped by a monoshock mounted horizontally under the center rear of the frame, forward of the rear wheel. The clutch is of the wet plate design and is hydraulically activated by the left hand lever. The brake system uses two disk brakes on the front and one disk on the right rear. All calipers are of four piston design.
  • 5 miesięcy temu...
Witam kupiłem Venture w zeszłym roku świeżo przywieziony z usa przez polaka który tam mieszkał i pracował, miał piękny przebieg 5000mil i to udokumentowany,mieszkam koło Wodzisławia Śląskiego co prawda sezon się kończy ale pogadać zawsze można,[email protected] Robert. Post edytowany: 07.10.2010 20:46
